Thread: C-47 Crash, Non Fatal
    The CAF C-47 from Highland Lakes squadron at Burnet, just outside Austin was lost on takeoff, news says the wing dipped and hit the ground. The photo shows the fuselage is mostly burned out with the engines and tail visible.
    The good news is it says all 13 survived,with some injuries, one serious. . Iven been to Burnet and been in that plane, Im a life member.
    Nov 2017
    For anyone interested, there is a video of the accident. Thank God everyone survived, the pictures looked far more dire than the video.
    An early view, by looking at comments on other sites as well as talking to some CAF members, I am a life member myself, may not give the final cause, but some seem to be ruled. Some have guessed that controls might have still been locked, but the pilots in charge so not so, all control locks were removed, and others say in the video they can see the rudder move to full right and maybe the elevator move. And the tailwheel was locked as it should be, the pin was found sheered after impact.
    They say with 13 people on board and baggage and gear, for a week at Oshkosh they were still under the gross weight limit, and had flown that way in the past.
    Still it was heavy and very hot that day over a 100* and the runway while adequate at 5000 ft is not that long. Just looking at the video it seems a little sluggish, the tail never comes up much and it seems to try to lift off when a little slow and the right wing descends then left wing and hits the ground. Just didnt look like fully enough flying speed. They said the engines ran fine, no problem there.
    All survived,but some had burns getting out.
