Page 6 of 6 FirstFirst ... 456
Results 51 to 56 of 56
Thread: Stall in a turn
  1. #51
    NW FL
    Ron and Ron, thank you for taking the time to set me straight. Dihedral. Of course. As for the separation moving span wise on the wing, years ago, in a SG 1-26 I was wrapped up in a tight turn, coreing a thermal at stall plus 2 or 3. I glanced back at the wing trailing edge at the fuselage juncture. There was a triangular area that was obviously, visually turbulant. The skin was vibrating. I eased off back pressure and the turbulant area grew smaller. increased back pressure and it got bigger. Looks like it was time to re- skin the wing.
    Bob
  2. #52
    Quote Originally Posted by Bob Dingley View Post
    Ron and Ron, thank you. Dihedral. Of course.
    There is a really good book by Hubert C. ("Skip") Smith entitled, "Illustrated Guide to Aerodynamics". I highly recommend it … lots of little yarn tufts so one can easily see what is going on. Obviously the yarn destroys any prayer of laminar flow
    I believe legally (but don't quote me … and I'll deny it) one can tuft an airplane without going into "Experimental" category. As an FAA Flight Analyst DER, you would think that I would know that answer. Guess I'm used to being in the "X" category all the time.
    You're welcome,
    Ron "we all learned something today" Blum
  3. #53
    Fort Vermilion Alberta
    Aileron should not be a factor in a stabilized turn. When banking the airplane I teach ,look, kick and turn, then neutralize, the airplane should continue at this bank angle (turbulence not withstanding) until you reverse the bank angle.
  4. #54
    NW FL
    Somewhat off topic. A late friend instructed in B-24 and B-29's in the early 40's (until he was shipped to Tinian). He told me that part of the B-29 check out included stalls in a 60 degree bank. Of course, the complete crew was aboard.
  5. #55
    Banned
    Practicing for steep turn to the left after simulating atomic bomb drop???
  6. #56
    Quote Originally Posted by raytoews View Post
    Unless one is flying an airplane with neutral or negative lateral stability, there will be a little down aileron on the up wing (and up aileron on the down wing). This may be masked by aileron system friction. We're not talking large amounts like 2-3 degrees, but there will be some. All certificated airplanes must have positive lateral stability.
