Thread: TIG welding electrodes, half length & high count for a compact torch, from JSP ARC
    Spencer_Gould's Avatar
    South Florida
    Goggles TIG welding electrodes, half length & high count for a compact torch, from JSP ARC
    Perfect for roll cages, motor cycle frames, & aircraft fuselages or anything else that uses a short torch setup.
    And with the 2% Lanthanated “blue band” it works great on inverter TIG machines, equally at home with AC & DC setups to give you coverage for Aluminum, Steel & Stainless.
    Half length sold in high rod count with a price point similar to other electrodes.
    They are available in 3 sizes & can be purchased & fulfilled by Amazon:
    .040"Ø (18) = https://goo.gl/UAo82f
    1/16"Ø (14) = https://goo.gl/ynYrwR
    3/32"Ø (12) = https://goo.gl/GwgnKe
