Results 1 to 8 of 8
Thread: Ultralight under 5k?
    I am looking to build an ultralight with zero building experience. I want something that is under 5k and takes less than 6 months to build. Is that even possible? I looked at the affordaplane but some people said theirs came in 100 pounds overweight.
    Sent from my SM-G950U using Tapatalk
    srbell's Avatar
    Huntington, WV
    Quote Originally Posted by thecantaloupeman View Post
    Check out Team Mini-Max https://www.teammini-max.com
    Sent from my VS996 using Tapatalk
    Quote Originally Posted by srbell View Post
    How much would it cost to build the 1100r from scratch if I bought all the wood and cut it myself? And then found a vw engine in a junkyard to fix and use in it?
    srbell's Avatar
    Huntington, WV
    I'm not sure, but there is a very actve and helpful users group where I'm sure you could get all the help youd need. Its one of the best forums I've seen. Check the out:
    http://www.lonesomebuzzards.com/cgi-...ah.pl/Blah.pl?
    Aug 2015
    Take a look at the ragwing line. You might be able to get the heath together with a rotax cheaply
    Apr 2018
    The Afford A Plane comes close to FAR103 weight and is a lower cost build but the original engine was only a 277 CC and was under powered. There is a group over on Facebook for the Official Afford A Plane build.
    robert l's Avatar
    Mar 2017
    Heath Springs, S.C.
    The Lonesomebuzzares have a lot of info on the Mini Max. Also, try Barnstormers, they come up for sale pretty often.
    Bob
    Jun 2018
    Another option is to buy a second hand kit that hasnt been completed yet. Seems like lots of them around,
    Buy them around 1/3 the cost of new or less. Lots of information on line to aid in building them. One with complete parts and directions is helpful.
    Jeff
