Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Park Plane Without Oil?
    Quote Originally Posted by Jeff Point View Post
    This is true, but is also why many of them develop cam/ lifter issues due to neglect.
    I agree, some of them develop issues. Lycoming recommendations are worst case scenario. I wouldn't call Arizona worst case. Know your environment.
    gbrasch's Avatar
    Arizona
    I think a 25 watt lightbulb in the cowl to keep it above dew point is all that is needed.
    But don't heat the bottom to make steam that condenses on the cold top and cam.
    Just keep it 10 above dew point.
    There is no dew point in southern Arizona, what is a dew point?
    Glenn Brasch
    KRYN Tucson, Arizona
    2013 RV-9A
    EAA member since 1980
    www.airportcourtesycars.com
    Jeff Point's Avatar
    Milwaukee
    Come up here in about 5 weeks and we’ll show you.
    Jeff Point
    RV-6 and RLU-1 built & flying
    Milwaukee, WI
    "It All Started Here!"
    It might drop below dew point in the evening from heat radiation out to the night sky if parked outside or perhaps in a hangar with a metal roof.
    Even in dry country, if you run it only a few minutes the moist combustion gas gets past the rings and into the crankcase. I think it was Piper that tested periodic short engine runs for storage and found it to be worse than no periodic runs at all. The oil needs to get hot.
    The upper surface of any tank tends to collect dew. My tractor diesel tank gets wet on the inside of the fuel cap.
    I suppose the same happens in a crankcase. I wouldn't worry about it. I do nothing here just 400 feet from the pacific coast.
