Results 11 to 20 of 24
Thread: Park Plane Without Oil?
    gbrasch's Avatar
    Arizona
    Thanks for the opinions. Glenn
    Glenn Brasch
    Tucson, Arizona
    2013 RV-9A / 1952 Piper Tri-Pacer
    EAA member since 1980
    www.airportcourtesycars.com
    www.facebook.com/airportcourtesycars
    Jeff Point's Avatar
    Milwaukee
    90% of the light GA airplanes is this country sit for periods longer than 6-8 weeks throughout their life.
    This is true, but is also why many of them develop cam/ lifter issues due to neglect.
    Jeff Point
    RV-6 and RLU-1 built & flying
    Milwaukee, WI
    "It All Started Here!"
    Aug 2015
    If it was used oil full of acid I could see a point to draining it. With new oil I can't see any point.
    In any case, you would be wise to follow the manufacturers recommendations. In the case of Lycoming SL 180:
    INACTIVE ENGINES:If it is known that an aircraft is to remain inactive for 30 or more days, the following procedure should be applied to the engine, especially if the aircraft is located near salt water or similar humid environment.
    https://www.lycoming.com/content/ser...etter-no-l180b
    Socal
    I put a pyramid on top of the engine. Never had a problem.
    Aeroshell fluid F
    Quote Originally Posted by gbrasch View Post
    I will be unable to fly my plane for 6-8 weeks. My plan is to change the oil and let the plane sit after flying it briefly with fresh oil and CamGuard. A friend suggested leaving it with the oil drained, he thought that might be better. I like my idea more, what say you mechanics? Thanks in advance. Glenn
    Have not any of you folks heard of Aeroshell Fluid F fly away preservative oil? Funny, nobody has mentioned it. I recall it's good as a preservative for 3 to 6 months, and can be flown at any time with a 50 hour limit.
  6. #16
    WA
    I think a 25 watt lightbulb in the cowl to keep it above dew point is all that is needed.
    But don't heat the bottom to make steam that condenses on the cold top and cam.
    Just keep it 10 above dew point.
  7. #17
    If you're using two 13W LED bulbs, should they be "Bright White" or "Soft White"? :-)
    Ron "Welcome to the 21st Century" Wanttaja
  8. #18
    Jeff Point's Avatar
    Milwaukee
    Quote Originally Posted by whankinson View Post
    This is precisely what I recommended in post #6, although not by brand name as there are others as well. This is Lycoming's recommended procedure. I think the time limit is 10 hours not 50, but I don't have the specs in front of me.
    Jeff Point
    Milwaukee, WI
  9. #19
    Aug 2013
    Gwinn, Michigan
    Fresh oil, Cam Guard, run up to warm oil. Shut down and don t move prop. Any longer, i would "fog" cylinders and comply with Lycoming proceedures.
    Bill landry
  10. #20
    Quote Originally Posted by CAVU Mark View Post
    One just has to ensure it is aligned to the Sun properly.
