Thread: Should Rod End Bearings for Ailerons use Zerk Fittings
    For my project airplane, the Acey Deucy, the ailerons are mounted on rod end bearings. In shopping for these bearings, I see that Zerk grease fittings are an option.
    I would appreciate learning from experienced builders whether these are useful.
    Thank you.
    Ref: https://www.aircraftspruce.com/catal...mmbearings.php
    Sam Buchanan's Avatar
    KDCU
    RVs use a lot of rod end bearings and none of them have zerks. Greasing these bearings is a great way to trap dirt and cause premature wear and rough operation. Best to use a non-stick lube such as one of the LPS products.
    By the way, the much less expensive Aurora bearings will work fine on your project.
    Sam Buchanan
    EAA Technical Counselor
    The RV Journal RV-6 build log
    YouTube Channel
    Thank you for the reply, Sam. Very helpful.
    cub builder's Avatar
    North Central AR
    Sam is exactly right. My KR has numerous rod end bearings as well, including the aileron push rods. At 22 years (aurora bearings) and 1200 hours, they are still nice and snug. I use Triflow to lubricate annually, but it's a very similar product to Sam's recommendation.
    Auburntsts's Avatar
    Dumfries, VA
    There's an EAA Homebuilder Hint video that explains the greasing procedure: http://www.eaavideo.org/detail/video...e&q=rod%20ends
    Todd Stovall
    PP ASEL - IA
    RV-10 N728TT - Flying
    My builder's log (which is woefully out of date): www.mykitlog.com/auburntsts
    WAR DAMN EAGLE!
