Thread: Cessna bolt ID
    May 2012
    Cessna bolt ID
    Does anyone have info on a Cessna 150/152 rudder stop bolt p/n 0433142-1 from Cessna kits SK152-24B and -25B ? Is the bolt strictly a Cessna proprietary part or does it has an MS or NAS equivalent ? I ask this because the little buggers are $103 each !
    I don't have an answer to your question. I would identify the existing bolt from looking at the bolt head.
    May 2012
    I finally got a look at one of those bolts. It is a Cessna proprietary bolt.
    Quote Originally Posted by Eric Brown View Post
    What is the difference? On a Cessna 120, one of the wing bolts is just a shortened AN bolt because to get the proper grip made the overall length too long so they just cut it off and gave it a Cessna part #.
    I'm interested in coming up with an AMOC for the rudder stop AD with off the shelf hardware.
    May 2012
    The Cessna bolt is a 3/16" bolt with a thin 5/8" hex head. It is threaded its full length. Bolt head is slightly domed.
