Originally Posted by
Tralika
If it were me, I'd want to get a close look at those "logs from day 1" before I paid. Also, you don't say if the plane is being built from a kit. If it is a kit, you will need a copy of the Bill of Sale (FAA Form 8050-2) from the kit manufacturer to the original purchaser of the kit. You will need another Bill of Sale from the seller you are dealing with to you. If there are any other owners of the kit between the kit manufacture and the seller you are dealing with you will need a copy of those Bills of Sale too. The FAA is very specific in that the Bill of Sale must be a FAA Form 8050-2. If the kit was made in Canada and sold to a Canadian, I doubt there will be a FAA Form 8050-2 and your into something unusual. Someone has probably been through it before but finding them might be difficult. If you contact the FSDO I doubt you will find anyone that knows much about Experimental Amateur Built let alone importing a partially completed kit from a foreign country. You might call the Canadian kit manufacturer and ask what type of bill of sale they use and if they have any contacts at the FAA they have dealt with when importing the kits to the US. Also, have the FAA Form 8050-2 notarized if you buy the kit. Other than the quality of the workmanship, the paperwork is going to be the most important part of your venture. Good luck.
