Mystery Clamp?
Given that the active builder community for my particular aircraft, an Acey Deucy, is basically ... just me, I will take the opportunity to use the larger EAA homebuilder community to ask the occasional question.
I am compiling a list of parts for the aircraft. My focus now is on the wings. There is one part mentioned in the plans that draws no relevant results via web searches. I suspect it is a clamp: AN-520-836.
(See accompanying image).
Does that part number ring a bell with any of you more experienced builders?
The need is for the securing of the aileron cable fairlead brackets, once they are positioned on the compression strut.
Thank you,
Mark Conover
