Results 1 to 10 of 10
Thread: Mystery Clamp?
    Mystery Clamp?
    Given that the active builder community for my particular aircraft, an Acey Deucy, is basically ... just me, I will take the opportunity to use the larger EAA homebuilder community to ask the occasional question.
    I am compiling a list of parts for the aircraft. My focus now is on the wings. There is one part mentioned in the plans that draws no relevant results via web searches. I suspect it is a clamp: AN-520-836.
    (See accompanying image).
    Does that part number ring a bell with any of you more experienced builders?
    The need is for the securing of the aileron cable fairlead brackets, once they are positioned on the compression strut.
    Thank you,
    Mark Conover
    I think it's calling out AN520 screws to attach the split 4130 tubing base of the fairlead to the compression strut. The diagram seems to show the holes for the screws, with a centerline through each pair.
    Sam Buchanan's Avatar
    KDCU
    Yep, those 'clamps' are to be fabricated by the builder using tube stock and the drawing specifies the tube sizes.. The AN callout is for hardware to secure the clamps to the structure.
    Sam Buchanan
    The RV Journal RV-6 build log
    Thank you, Dale.
    I would think that, once the fairlead bracket assembly is positioned correctly on the compression strut, it could simply be welded in place.
    Any reason to think that, over time, the location of the bracket might need to change? I doubt that. But, I also have no experience with this type of airplane (only spam cans).
    KDCU
    That was my first thought but I wasn't sure if the compression strut was 4130 or aluminum. If steel the tube retaining the fairlead could be directly welded to the strut without the "clamp" tube. That was how the fairleads on my Legal Eagle were attached.
    Sam Buchanan
    That particular compression strut is 4130. So, I do foresee just welding it in place.
    Thanks, Sam.
