If you are on the ILS approach here there is no way you will make the airport if you lose power, unless you are really close to the end of the runway. There are plenty of safe spots to land if you need to, but if you are doing the ILS approach because you NEED to use it you probably won't be able to see the ground. Fortunately our airport has flat farm ground on the approach ends of most of the runways. A few years back a Bonanza lost power on final & took out 1/2 acre of corn, but the pilot was uninjured.
