Results 1 to 7 of 7
Thread: Need a constant speed prop
    Apr 2018
    Conroe, TX
    I am in need of a new or low time Hartzell Prop model PROP C2YL-1BF/F7663-4. The prop is going on an I0-320 Lycoming.
    Van's RV sell them new for $7,900.00 but only to Van builders. A low time used one will work just fine.
    Any ideas or suggestions would be appreciated. A new prop direct from Hartzell is $13,000. Whirlwinds price is similar.
    Thanks in advance for you help.
    JP
    gbrasch's Avatar
    Arizona
    Are you stuck on that idea? Catto makes a beautiful prop.
    Glenn Brasch
    KRYN Tucson, Arizona
    2013 RV-9A
    EAA member since 1980
    www.airportcourtesycars.com
    Apr 2018
    Conroe, TX
    Glenn,
    Thank you for the suggestion. Their web site does not provide much product information but I did ask for a quote. I will soon need to do a weight and balance to see if I can use a carbon fiber prop. Addressing CG concerns is a real issue as the plane has a pertinacity to be tail heavy and a 51 pound Hartzell prop would take care of that issue but so would a larger batter in the engine compartment.
    I appreciate the reply, Thanks again.
    gbrasch's Avatar
    Arizona
    Quote Originally Posted by JPCrew View Post
    Glenn,
    Your welcome!
    Glenn Brasch
    2013 RV-9A
    Apr 2018
    Conroe, TX
    Glenn,
    Just spoke to the Catto prop folks. They make a very nice prop but do not have a constant speed prop quite yet. They have one in development and are looking at a price close to that of a Hartzell and a Whirlwind, ($13,000.00). Thanks again for the suggestion and I thought I would just pass that info along to you. Have a great week,
    JP
    Jul 2017
    Douglas Flat, CA
    ...Van's RV sell them new for $7,900.00 but only to Van builders...
    How much is an RV tail kit?
    Bob Kuykendall
    HP-24 kit sailplane project
    HP-24 Project Facebook Page
    EAA Technical Counselor
    Apr 2018
    Conroe, TX
    BoKu,
    That's a good question. I had thought about asking a RV builder who has used a fixed pitch prop to buy 1 for me and I would reimburse them. I have bought a lot of items from Vans but they don't want to budge on their policy. I'm about 6 months away from completion. Many items on my bird are similar to the RV 7. I have a Smyth Sidewinder over 90% complete. I had a build in progress when my son found a plane which was complete. The builder did exceptional work and took the extra mile on everything he did. He passed and left the plane to a friend who stripped it and sold it to us for much less than we could have finished our built. I have spent the last 3 years building an engine and re-engineering a few necessary items. Much of the RV is like the Sidewinder with exception the fuselage is 4130 steel and the wing as a progressive airfoil. The wing span and fuselage length are about the same. The plane is less forgiving but the trade off is the performance. I find most RV builder do not have good things to say about the Sidewinder. They love their RV and the RV is a good plane. They both have their pros and cons. Like the prop, it takes the same model and diameter for either the O-320 or O-360 engine.
    Good hearing from you,
    JP
