Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: RV 7A Maintenance
    Aug 2013
    Gwinn, Michigan
    RV 7A Maintenance
    I am doing a Condition Inspection on a friends RV 7A ( he is not the builder and not a holder of repairman cert, yes, I am an A&P in case someone was wondering). As he has no manual for the plane, I am trying to find out how to jack this beast especially the nose so i can do the caster inspection . The checklist he has given me does not have this information.
    Bill L.
    Quote Originally Posted by skyfixer8 View Post
    Bill L.
    With the cowling off, you can use an engine hoist or on the other end use the tail tie down ring.
    Sent from my iPad using Tapatalk
    Aug 2013
    Gwinn, Michigan
    Thanks Tim. Was wondering about tail tie down but wasn t sure. Had to ask
    Oct 2014
    Tehachapi, CA
    There are threaded jackpoints in the wings, about 2/3 outboard.
    See:
    https://www.vansaircraft.com/pdf/How...k-up-an-RV.pdf
    https://bogertaviation.com/products/rv-jack-pads
    https://antisplataero.com/products/quality-jack-points
    On the taildragger versions, the design is less than optimal due to the angle of the jack on the wing (unless you substantially raise the tail first).
    Here's a different solution:
    http://www.wintermotorsports.com/jackpoints
    Aug 2013
    Gwinn, Michigan
    One more question for RV experts out there. I know on Grumman tiger and Tecnam planes I have worked on, there is a "pull factor" on the nose gear swivel system. Anyone out there know if that applies to the RV 7A ? Wish there was a manual for this plane.
    There is a specified breakout force. 22 lbs at the axle.
    Aug 2013
    Gwinn, Michigan
    Thanks kyle
    Welcome to the world of homebuilts.
    Few have manuals like certified aircraft; and anything from the seller of the kit is actually just a recommendation.
    The assembly manual that is included with the RV-7A kit has detailed instructions for adjusting the breakout force of the nose gear. Construction drawings, manuals and associated documents can be purchased on a USB flash drive from Vans for $10, every owner and A&P should have this:
    http://www.vansaircraft.com/cgi-bin/...oduct=fd_plans
    These documents are not merely recommendations, they are the 'RV Bible'. You also need a complete set of Service Bulletins:
    http://www.vansaircraft.com/public/service-rv7.htm
    YouTube Channel
    Very gently I'm going to differ from your statement, Sam, as it was too specific, and we're speaking to an A&P.
    The build instructions for any aircraft are in fact recommendations - very serious ones - but the builder is free to deviate from them as they wish. The wisdom of this is usually suspect, but it's the truth of the matter. And the FAA couldn't care less if the builder did so.*
    Likewise, Service Bulletins aren't binding in Experimental Aircraft like AD's are in certified one.
    Again, one would be foolish to disregard them, but there is nothing compelling a builder/owner from following them.
    * Naturally, if one is building an E-LSA, then everything has to be the same to obtain and keep the category.
