Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: RV 7A Maintenance
  1. #21
    Shiloh, IL
    Quote Originally Posted by skyfixer8 View Post
    the original builder had riveted all baffles to the engine with cherry max. Spent most of the morning drilling them out so I could get the cylinders off.
    What does this even mean? The baffles are installed on the engine with screws. How could they be riveted?
  2. #22
    Aug 2013
    Gwinn, Michigan
    Sides are attached with screws to cylinders, however, front baffles riveted to sides and rear baffles same way on left and right side of engine. Had to remove rivets in order to pull baffles off for cylinder removal
  3. #23
    Sam Buchanan's Avatar
    KDCU
    Quote Originally Posted by keen9 View Post
    I'm 'baffled' by this as well.....yes, the sides are riveted to the front and rear, but they are joined in the middle with screws (cleco clamps in the photo) so each 'half' can be removed. I didn't drill out any rivets when I did an engine overhaul on my RV-6 O-320.
    Sam Buchanan
    EAA Technical Counselor
    The RV Journal RV-6 build log
    YouTube Channel
  4. #24
    Marietta, GA
    RV-6 owner here. 10-12 hours of focused time to do the inspection. Add 50% for the loss of efficiency due to drop in visitors, potty breaks, interest net surfing on the phone, and the like.
