Results 1 to 4 of 4
Thread: Precision Propellers, replacement blades needed
    Nov 2013
    Mount Perry, Ohio
    does anyone know who is making the wood replacement blades for Precision Propellers, hubs.
    I have a good 2 blade hub, and need 2 new blades.
    I tried an online search and found nothing.
    Robert
    I'd talk to Culver Props - http://www.culverprops.com/index.php
    While they usually make one piece props, if you have an old one they can probably use it as a pattern and make you replacements.
    Nov 2013
    Mount Perry, Ohio
    I have the stubs, so that might be enough, thank you for that suggestion.
    it does not hurt to ask.
    Robert
    The stubs are the critical part, I suspect. The length and pitch of the blade is what they do.
