Page 21 of 23 FirstFirst ... 111920212223 LastLast
Results 201 to 210 of 222
  1. #201
    bookmaker's Avatar
    Florida Panhandle
    Both sides of the rudder are now covered, shrunk and the fabric riveted to the rib.
    Although it doesn't look like it, the distance is the same between all rivets.
    The area around the control horn wasn't doing what I wanted, so I cut reinforcements from .010" aluminum that will ultimately be covered with a doily.
    Now on to tapes and doilies.
    Dale Cavin
    Florida Panhandle
  2. #202
    "A foolish consistency is the hobgoblin of little minds, adored by little statesmen and philosophers and divines. With consistency a great soul has simply nothing to do. He may as well concern himself with his shadow on the wall." - Emerson.
  3. #203
    bookmaker's Avatar
    Florida Panhandle
    Rudder taped ready for primer.
    I made a dogbone patch to fill the intersection of the perimeter tube and spar. Also covered the aluminum reinforcement around the control horn with a doily.
Size:  33.6 KB Name:  m_DSCN2171.jpg
Size:  14.6 KB Name:  m_DSCN2172.jpg
    After sticking the perimeter tape to the outer edge, the tape is shrunk to fit the curves. Then glued down.
Size:  27.5 KB Name:  m_DSCN2191.jpg
    Extra image - OOPS
    Dale Cavin
    Florida Panhandle
  4. #204
  5. #205
    Nice! I gather you've figured out the tapes are actually the most difficult part of covering!
    (At least for me it is)
  6. #206
    bookmaker's Avatar
    Florida Panhandle
    I applied the provided fabric sealer to the second side of the rudder.
    The first side didn't go quite as well as I did not filter the sealer well enough and ended up with a lot of little bumps. They are a pain to get out, but I am getting there.
    We have other commitments coming up, but I hope to get it painted in a couple weeks.
    Dale Cavin
    Florida Panhandle
  7. #207
    bookmaker's Avatar
    Florida Panhandle
    It's been a while since I posted here, and it is going to be a while longer before any significant progress is done on the N-17. We took a direct hit from hurricane Michael. Although we are nearly 60 miles from the coast, we officially had 125 mph sustained winds and the neighbor's anemometer broke over 150 mph. To put it mildly, we have a real mess here. While my house survived with very minor damage, and the N17 and my other planes survived, we lost our camper, shelter for it, the truck that carries the camper and untold trees.
    It will be months cleaning up, so the N17 has to be on the back burner. Maybe if I get a few minutes I'll try to do a little more painting on the rudder. Otherwise, it's on hold.
    Dale
    Before - North up
    After - North to the left
    Dale Cavin
    Florida Panhandle
  8. #208
    bookmaker's Avatar
    Florida Panhandle
    Just an update that there is no update. Other issues compel my leaving the N17 alone for a while yet.
    Dale Cavin
    Florida Panhandle
  9. #209
    bookmaker's Avatar
    Florida Panhandle
    There is not much to report. Cleaning up after the hurricane and tax season have pretty much taken up my mental capacity. However, some good friends helped remove the upper wing structure from the fuselage today and set them on racks. As soon as I get a little time, I will clear a spot at my home shop and move the fuselage here to complete the controls, firewall, engine mount and fairings. I am hoping to make some major headway this summer.
    Dale
    Dale Cavin
    Florida Panhandle
  10. #210
    bookmaker's Avatar
    Florida Panhandle
    Baby steps.
    Rose and I brought the fuselage to the home shop last weekend. I have a little time this evening to start on the central controls. The carry-through tubes are carefully drilled for the bolts that mount the torque tube ball joints.
    Then the torque tube ends are massaged to fit into the torque tube, then drilled for the attachment bolts. I need to shorten he torque tube a little to provide positive clearance.
    Not much, but something. Keep in mind we are still cleaning up the disaster from Hurricane Michael. Six months and no federal relief package.
    Dale
    Dale Cavin
    Florida Panhandle
