Page 17 of 23 FirstFirst ... 71516171819 ... LastLast
Results 161 to 170 of 222
  1. #161
    bookmaker's Avatar
    Florida Panhandle
    Frank, The thingy with the clecos. It probably has a more official name, but I don't know what it is.
    Dale Cavin
    Florida Panhandle
  2. #162
    I think it's "gap seal."
    I did something similar at first, but then found it wasn't necessary, and would have been a huge PITA to cover. Then again, you can remove the ailerons.
    I'm still very concerned you haven't given enough room for the fabric and it's going to rub.
  3. #163
    bookmaker's Avatar
    Florida Panhandle
    Frank, it is close, but there is sufficient room for a clean covering job. I will wrap the aileron around the leading edge, so that will keep the covering count low there, and be careful about build up on the wing side.
    Thanks for keeping watch on me.
    Dale
    Dale Cavin
    Florida Panhandle
  4. #164
    Well, your plane is a cousin to mine, so we're related by aircraft.
    I'm really, really looking forward to seeing it when it's finished. Heck, I want to park mine next to yours and walk from plane to plane saying "oh, that's better!" and "Yep, he did the same thing."
    We're just about one full tank of gas and a great story away from each other.
  5. #165
    bookmaker's Avatar
    Florida Panhandle
    Yes, we'll bring them together one day. Hopefully in the not to distant future.
    Dale Cavin
    Florida Panhandle
  6. #166
    bookmaker's Avatar
    Florida Panhandle
    Another hurdle cleared. Today, Rose helped me complete the aileron cutout fairings - top and bottom.
    Top
Size:  64.0 KB Name:  m_DSCN2024.jpg
    Bottom
Size:  53.2 KB Name:  m_DSCN2030.jpg
    Sometimes, it just takes the right size hammer.
    Dale
    Dale Cavin
    Florida Panhandle
  7. #167
    Wonderful craftsmanship with a great eye for detail!
  8. #168
    bookmaker's Avatar
    Florida Panhandle
    Rose and I had some time to work on this project yesterday. We mated the two top wings together for the first time with ribs. (still need false ribs on the left wing). The purpose for this was to match the root ribs wing to wing. We got the forward end of the left root rib positioned and a spacer between the upper and lower rib attached.
Size:  85.5 KB Name:  m_DSCN2032.jpg
    The left wing is back on the table for framing out the cockpit cut out, shrouds around the wishbone and final bracing of the root rib.
Size:  56.8 KB Name:  m_DSCN2035.jpg
    Dale Cavin
    Florida Panhandle
  9. #169
    bookmaker's Avatar
    Florida Panhandle
    Rose and I moved the wing to the lean to (after moving my boat that has been neglected for the last couple of years). The purpose was to be able to match the left wing root area items with the right. Last week, all was going well until it was discovered the left upper pilot cutout bow interfered with the aileron control wishbone at full deflection. We measured and measured and found nothing different from the right side more that 1/4 - 3/8" different. However, due to the hard arc, it hits. After letting it sit a few days we went at getting the parts to fit. Job complete. We had to shift the bow a little and associated parts, but it isn't obvious. We made a lot of progress.
    We now have to flip it to work on the bottom side.
    Dale Cavin
    Florida Panhandle
  10. #170
    bookmaker's Avatar
    Florida Panhandle
    Work in the last couple days produced two complete upper wings (except for covering)
    Now, how do I get these monsters up on the struts???
    Dale Cavin
    Florida Panhandle
