Page 18 of 18 FirstFirst ... 8161718
Results 171 to 173 of 173
  1. #171
    bookmaker's Avatar
    Florida Panhandle
    Wings on temporarily. However, I have decided the wing incidence needs to be reduced. The plan dimensions end up with 4 degrees at spar centerlines. That seems way too much. After discussing with Robert Basley, I plan to reduce the incidence measurement down to about 1 degree. Unfortunately, that requires. replacing some of the vertical fuselage members. However, better to fix now tha after it is giving problems flying.
Size:  77.1 KB Name:  m_IMG_6661.jpg
    Dale
    Dale Cavin
    Florida Panhandle
  2. #172
    bookmaker's Avatar
    Florida Panhandle
    Yesterday we bit the bullet and started the modifications to lower the wing incidence. The process was to lower the fuselage tail to bring the jigged angle from 4 degrees to 1.2 degrees that Robert says he uses on the new versions. The first shot shows how much we lowered the tail support.
    Redrilling the forward vertical fuselage member for the carry through attachment.
    New fuselage angle. The wing spars are horizontal.
    Dale
    Dale Cavin
    Florida Panhandle
  3. #173
    Now that's ingenuity.
    Instead of tilting the wings, you tilted the fuselage. Neat.
