Page 4 of 4 FirstFirst ... 234
Results 31 to 36 of 36
Thread: EFR rating: When VFR rating is not anough and IFR rating is too much.
  1. #31
    Oct 2014
    Tehachapi, CA
    Don't forget to carry over the 6 hours of currency from the requirements for being legal to file IFR...
    I don't remember when they got rid of that, but to be legal to fly IFR you need to follow 14CFR Part 61.57, which only has the following three requirements for IFR:
    within the past 6 months:
    6 approaches
    Holding Procedures and tasks
    Intercepting and tracking courses using navigational electronics
    No more instrument "time" requirements...
    Obviously, all the general requirements apply.
  2. #32
    Right, but my point was that guys who just fly enroute and don't do approaches will be required to have some sort of currency requirement to satisfy the ELOS. Which will be problematical for the pilots who only fly 10 hrs a year but want to fly through clouds.
  3. #33
    1997. >20 yrs ago.
  4. #34
    Quote Originally Posted by PlaneDan View Post
    Thank you for the link and advise. I will prepare and submit a proposal. However I suffer no delusions that this will ever come to pass in my lifetime. When I get a docket number, I will post it on this site. If anyone wants to join me in this endeavor, please let me know.
    Not to be Debbie Downer but it could be over quite quickly if they outright reject your petition. Yes, if they give it consideration it could be a lengthy process because they have to consider all ramifications. It took from 1989 to 1995 to rewrite Part 61 so I wouldn’t think it will take that long but 1-3 yrs is probable.
  5. #35
    Mar 2018
    Gatineau, Qc, Canada
    I have been preaching exactly that to anyone who would listen and have also suggested it to the FAA once when I had the opportunity. It is often met with the same response as the "I don't cotton to" one that you got. How often are you ready to go, and there is an overcast at 1000 ft., and tops at 3500 or so, and your destination is either VFR or at least is VFR below 1000 AGL? So you have to sit on the ground or commence on one of the most dangerous ventures in aviation known as "SCUD running".
    In my opinion, IFR is the most safe way to fly. I have equipment that is probably better than most aircraft in the GA fleet that are certified IFR. I don't have a rating, but would certainly pursue the EFR ( what does that stand for? ) if there were one. There is a special VFR, and I would call this a special IFR.
    To get a full IFR rating and equip my plane with the minimum required for GPS approaches, would cost a minimum of $20,000. I can fly on instruments, I do have synthetic vision and autopilot, but without adding an almost useless piece of certified equipment ( and that is all you could get for $10,000 ), it is a no go. Training for the current IFR rating would cost at least $10,000 with IFR Certified plane rental. This Special IFR or EFR rating should cost no more than half that. To be able to do what you have suggested, and what I have been preaching, for that price, I will jump on it in a minute and never again even be tempted to venture into that dangerous venture known as "SCUD running"
    Thanks for bringing it up!
    Hello Dan,
    EFR stands for Enroute Flight Rules (my suggestion).
    I did a presentation at my local club and all VFR pilots were very interested to get this licence. This may be a step towards their IFR rating. They will take instrument training and will be safer pilots. They will get more utility of their airplanes. Lots of pilots stop flying because they cannot fly nowhere because of the wx.
  6. #36
    Mar 2018
    So the original poster is in Canada. Would likely be more helpful to him to post a link to the Transport Canada rules change petition process. If there is real motivation to try to create change, he is much more likely to get the process started successfully on his home turf.
    But the posters above who are in the US (Joe citizen) can indeed step up and learn how the FAA works. Warning, great persistence is required. Plan on the process taking years.
    Thanks!
    I started to talk to my local club and my plan is to talk to larger VFR private pilot groups and at the end those groups will talk to COPA (your AOPA). I would like COPA to present this idea to TCCA (your FAA).
