Traditional aircraft tubing fabrication used OxyFuel but today we have other welding methods to chose from. What say you?
Edit: For readers confused : GMAW is the correct name for MIG and GTAW is the correct name for TIG (both no longer using exclusively inert gas) OxyFuel is the correct name for Oxygen with some other inflammable gas traditionally Acetylene
Modern electronics allows GMAW-P https://www.millerwelds.com/resource...to-pulsed-gmaw
