Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Medical for Experimental
    May 2016
    Pardon my ignorance (and yes I tried to search for the answer) What are the medical requirements to PIC Experimental aircraft in the US?
    lnuss's Avatar
    Dec 2013
    Colorado
    Same as for any other aircraft. The medical requirements vary by the type of pilot certificate, not type of aircraft.
    Larry N.
    If you want to operate an experimental as a light sport aircraft and exercise only sport pilot privileges, no medical required even if you hold an ATP certificate.
    [See details on package, offer valid in all 50 states, void where prohibited by law]
    Well not by type of "airworthiness certificate" but rather the type of pilot certificate required.
    As pointed out, if it is an LSA, then a sport pilot (or higher) can fly it without a medical. Gliders, LTA, etc.. also.
    Airplanes that don't qualify as LSA, require either a medical certificate or the new "basic med."
    A Homebuilt motorglider doesn't require any medical or drivers license.
    Even if heavier than 1320 pounds.
    Not to split hairs, but that's not entirely true.
    Sport Pilots must have a motor vehicle license, which is their medical - if one fails the eyesight or other tests of medical fitness for one, they also lose their flying priledges. Heck, lose one's driver's license for any reason and one is legally grounded.
    Private pilots may fly under Sport Pilot rules, but clearly they must have a physical, even if it's not currently updated. If their physical is revoked for any reason, they are grounded when it comes to LSA qualified aircraft.
    As previously stated, EA-B aircraft are, well, aircraft, and are treated no differently than certified ones when it comes to permits and ratings. A twin engine experimental requires the pilot to be multi-engine rated, a conventional gear one requires a tailwheel endorsement, etc.
    You are splitting hairs and what I wrote WAS entirely true. You just provided additional details.
    Now you are the one that is wrong. While an experimental makes no difference for the medical, it is true (as I correctly stated the MEDICAL is contingent on the PILOT certificate required), experimental do have some exceptions. You might want to read 61.31 again more carefully.
    Not quite. An experimental aircraft flown solo does not require the pilot to have any category or class ratings, or endorsements. If carrying a passenger, then the requirements do apply. So if your pilot certificate says "airplane single engine land", you can legally solo a seaplane, multi, glider, or even a helicopter.
    Auburntsts's Avatar
    Tampa, FL
    Do you have the ref for that? In any event, the aircraft’ OPLIMs may dictate otherwise—mine certainly do. Specifically they state that the PIC must hold an appropriate cat/class rating and have logbook endorsements required by 61.31(e), (f), (g), (h), (i), and (j).
    PP ASEL - IA
    RV-10 N728TT - Flying
    EAA Lifetime Member
    WAR DAMN EAGLE!
    Read 61.31(l) again. It exempts the earlier limitations for experimentals without passengers.
