Originally Posted by
Dana
Maybe it won't be as "historically significant", but consider that a used experimental will always be more bang for the buck than any standard certificated aircraft. No A&P needed except for the condition inspection, no requirement for original/TSO/STC'd parts, change anything you want, etc...
IIRC the C-175 has the geared engine which has its own set of issues...
