How do you get the correct torque setting when you are tightening bolts with elastic stop nuts?
Originally Posted by mcmurphy How do you get the correct torque setting when you are tightening bolts with elastic stop nuts? Measure the torque required to turn the nut against the nyloc insert only and add that to the correct torque specification.
Sam Buchanan The RV Journal RV-6 build log Fokker D.VII semi-replica build log
