Thread: State of the Art Novel InFlow: 1-Gearturbine-RotaryTurbo, 2-Imploturbocompressor1Comp
    retrodynamic's Avatar
    Sep 2017
    Monterrey NL Mexico
    Lightbulb State of the Art Novel InFlow: 1-Gearturbine-RotaryTurbo, 2-Imploturbocompressor1Comp
    Featured Project Development - State of the Art Novel InFlowTech;
    1-Gearturbine RotaryTurbo, 2-Imploturbocompressor One Compression Step.
    *Wordpress Blog State of the Art Novel InFlow Gearturbine Imploturbocompressor:
    http://stateoftheartnovelinflowtech.blogspot.mx/
    *-1:
    Name:  Gearturbine Lateral Cut Technical Draw.jpg
    -YouTube; * Atypical New • GEARTURBINE / Retrodynamic = DextroRPM VS LevoInFlow + Ying Yang Thrust Way Type - Non Waste Looses
    *1-GEARTURBINE BEHANCE Images Gallery Portafolio:
    https://www.behance.net/gallery/2101...urbine-Project
    ·1; Rotary-Turbo-InFlow Tech / - GEARTURBINE PROJECT Have the similar basic system of the Aeolipilie Heron Steam Turbine device from Alexandria 10-70 AD * With Retrodynamic = DextroRPM VS LevoInFlow + Ying Yang Way Power Type - Non Waste Looses *8X/Y Thermodynamic CYCLE Way Steps. 4 Turbos, Higher efficient percent. No blade erosion by sand & very low heat target signature Pat:197187IMPI MX Dic1991 Atypical Motor Engine Type.
    *-2:
    Name:  Imploturbocompressor front cut.jpg
    *2-IMPLOTURBOCOMPRESSOR BEHANCE Images Gallery Portafolio:
    https://www.behance.net/gallery/2169...turbocompressor
    ·2; Imploturbocompressor; Implo-Ducted, One Moving Part System Excellence Design - The InFlow Interaction comes from Macro-Flow and goes to Micro-Flow by Implossion - Only One Compression Step; Inflow, Compression and outflow at one simple circular dynamic motion / New Concept. To see a Imploturbocompressor animation, is possible on a simple way, just to check an Hurricane Satellite view, and is the same implo inflow way nature.
    State of the Art Novel InFlowTech Project Development; ·1-Gearturbine RotaryTurbo Retrodynamic = Dextro RPM VS Levo InFlow + Ying Yang Way Power Type-Non Waste Looses, Similar Aeolipile System 10-70 AD, Pat197187IMPI MX Dic1991 / ·2-Imploturbocompressor One MovingPart System Excellent Design and One Compression Step to, Similar to Hurricane Satellite View, Same Implo inflow Way, from Macro to Micro.
