Originally Posted by
DaleB
I would say even if you are flying a Cirrus, the next few minutes are going to be very challenging. With no parachute, you have to pick a spot to land if there is one, or the least bad place to crash. Now you've got to either land, not screw it up, and pray there's nothing you didn't plan for -- or crash as slowly as you can and hope for the best. If you have a chute, you have to figure your chances of landing safely, then decide if your chances will be significantly better if you pull the handle. Me... if I had that option... if a safe landing were not assured, I'd pull the handle and call it a day.
