Results 11 to 20 of 28
Thread: Homebuilt Powered Paraglider Quad
    Quote Originally Posted by Michael Miles View Post
    Thanks Dana - I'll check those out. Not quite sure how I'll post things, Is this not a good place to do that? I just bought a 36hp Subaru 4-stroke, so onward and upward...
    Posting here is fine, I just suggested those other sites because that's where most of the ppg pilots hang out, lots of expertise there.
    Ok, the engine, prop, redrive, and bearing puller is in the mail. I'll post some pics when I get them. Michael
    What part of the country are you in Michael?
    Grazhopper is a nice machine. http://www.airparamo.com/equipment/t...azhopper.shtml
    I'm in eastern NC. I'm building a Quad - are there plans or kits for a quad grazhopper? I'm building a quad because I think they are safer. I saw a trike crash and flip over on its side during landing, and I'd like to have the extra ground stability of a quad. I also want all the advantages of a 4-stroke engine
    OK, I think what I'll do is use this thread to document the overall project, and I'll post links to specific questions I ask in other threads. Here's the first one on swapping for sealed ball bearings in the wheels:
    http://eaaforums.org/showthread.php?...pping-question
    Michael
    Picture of engine and seat on lift cart with wheels. Note the front wheel has the new sealed ball bearings.
    Redrive unit and 59 inch prop:
    OK, I emailed Ashton Brunner at http://flygreeneagle.com/ about plans for the Green Eagle PPG, and will let you know what the scoop is.
    Michael
    Michael;
    You look well qualified in the design/build department. I see no problems and the tandem wing will do well. OK if used should do fine. After soome work with it you can have it inspected for airworthiness.
    I strongly recommend getting some instruction when the time comes. Another pilot if not a PPG/CFI. You will drive yourself crazy otherwise and brake a lot of expensive equipment. I am on www.homebuiltairplanes.com post there also. Contact me at HBA when nearly ready to fly if you have no other instruction.
    Hi folks:
    Just wanted to bump the thread. I've been on hold due to financials (as is usual with this hobby), but I've been thinking (still free). I spoke with Ashton Brunner, and he gave me a lot to think about. In particular, it seems like I won't be able to bend the frame myself (requires specialized expensive equipment), but I may be able to buy a frame alone from him. He said I've got a good engine for the application. In addition, I'm waffling between the paraglider and powered parachute wing. I'll post the latest thoughts and info soon.
    Michael
