EAA/NTSB Safety Survey for Experimentals
The NTSB, along with the EAA, is conducting a safety survey of experimental aircraft builders and owners. The survey is located at:
www.eaa.org/AB-survey
I took the survey in about 10 minutes. It seem to be well thought out and can help the safety of the entire E-AB fleet.
I agree...I took it yesterday morning, ten minutes for me as well, and I thought it was very well done and worth the time to take part.
I took it and also posted the link to Vans Forum. Well thought out survey, be prepared with your weights and airspeeds.
