glue
My plane is finished in poly fiber I would like to put more inspection holes on wings what would be the most economical glue to use? would gorilla glue work?
If you're sticking things (inspection rings) to the fabric, you need to be using PolyBrush. It's the only proper (and in the case of certificated birds, legal) thing to do.
http://www.polyfiber.com/techquestio...ings/index.htm
What Ron said... and you should never use Gorilla Glue for anything in an airplane. Although it's great for projects around the house and joints with gaps, it dries brittle and I wouldn't trust my life with it.
