Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: What's your experience?
  1. #21
    FA40
    Who remembers the mis fueling that happened in California? 4 major airports had less than 5% diesel contamination?
    the engines torn down by Lycoming and TCM all had signs of detonation present..
    what is the major ingredient in MMO?
    I'm kind of slow. At the MMO-recommended 4oz per 10gal, does that make the engine digest 3.125% or .3125% ? Because that might be significant or no big deal. Depending. But it's still LARD?
  2. #22
    Nov 2012
    More precisely: 74 percent mineral oil, 25 percent stoddard solvent, and 1 percent lard (aka pig fat)
    Caveat emptor my friend
    Have you ever used break in oil? It's castol oil. Says it right on the bottle. Castol oil nothing more then plant oil.
  3. #23
    If we are going to use faulty logic, we could conclude from your experience that the valves didn't stick despite the use of MMO, not because of it.
    Somewhat amusing that despite an engine manufacturer publishing a document expressing prohibiting use of a product is not satisfactory to overturn folklore.
    I'm sure we all appreciate your smart ass comments. In case you didn't read the question, the poster was looking for experience using the product. I gave my experience.
    He did not ask for opinions. Opinions are like ass holes. We all have them.
  4. #24
    Oct 2014
    Tehachapi, CA
    I'm with you that there is no objective statistically significant evidence that MMO does anything for either stuck valves or for that matter, lead scavenging, although it DOES have a tiny bit of TCP in it, which is used for lead scavenging. Multiple anecdotes do not equal data - I've NEVER used MMO in my engine over a 15 year period and have never had a stuck valve - what does that prove? But there's no evidence that it does any harm, either, unless you really don't like the smell (which I don't).
    With respect to the question of "lard", the MSDS for MMO:
    http://www.audiosears.com/MSDS/FS043...tery%20Oil.pdf
    indicates five total components, none of which are animal derivatives. There's no lard in MMO, according to the folks that make it.
  5. #25
    Oct 2014
    Tehachapi, CA
    Quote Originally Posted by Mike M View Post
    4/1280 = 0.003125, or 0.3125%. Other than sell some MMO, I can't imagine that it has any effect whatsoever, but YMMV.
    And no - see my post above - no lard, according to the MFG. Some weird OWT, apparently.
  6. #26
    The NTSB investigation indicates it can cause damage to an engine and an engine manufacturer seems to be convinced well- to the point they will void a manufacturer warranty.
    WRT the composition, I am not making any claims. Only reporting what the NTSB found
  7. #27
    Oak Harbor Wa
    Question,, Does adding any amount of oil to your fuel raise the BTU content of that fuel?
  8. #28
    Quote Originally Posted by dothetime View Post
    I'm sorry. I thought you asked a question as well.
  9. #29
    FA40
    If oil has more BTU per volume, I'm guessing "yes"
