Thread: For Sale: N8547J 1967 Cessna 150G
    Eagle Six's Avatar
    Oct 2013
    Navajo County, Arizona, USofA
    1967 Cessna 150G N8547J (aka Scooter)
    TTAF: 3333 hours
    TSMO: 1516 hours
    Last Annual: 12-17-2016
    - - - - - - - - - - - - - - - - - - - - - UPDATE 06-13-2017 - - - - - - - - - - - - - - - - - - - -
    0-200 engine recent inspection (06/13/2017): Cylinder bore scope, all valves, walls, and piston heads reported as normal, no cracks or burns. Cold compression test reported as 1=74/80, 2=78/80, 3=74/80, 4=72/80. Plugs good, cleaned and set. Changed oil and filter, sent oil sample to Blackstone Labs, which report engine has no obvious signs of trouble.
    Narco CP135 TSO switch
    TKM MX11 Comm
    Narco AT 150 TSO transponder
    Attitude Gyro, Directional Gyro, VOR
    Alcor EGT
    Sporty's Flight Timer
    Flightcom IIsx Intercom
    Bruce's Prop Cover
    Bruce's Pitot Cover
    Bruce's Intake Covers
    Bruce's Windscreen Insert Reflector
    3 New Tires (nose + mains) GoodYear Flight Special II
    Aero Fabricators Dual Harnesses
    Belly Fuel Drain
    Hoerner Style Wing Tips
    Micro AreoDynamics Micro Vortex Generators (VG) + replacement kit
    Wheel Fairings - matching paint
    Log books, parts manual, service manual, lots of paperwork
    EAA AutoGas STC
    Asking $21,500.00
    Located at Taylor Airport (KTYL) in Taylor, Arizona
    George 623 six nine four 4901
    George Dean
    CP-ASMEL/I, S-6ES
    EAA, APA, & AOPA member
    KTYL/KGEU, EAA White Mountain Chapter 586 - Show Low Regional KSOW
    "If you go down, go down standing up"
