Shannon, any plane can be made experimental by alteration away from the original type certificate. As an example, planes that have sections of fuselage removed for camera portals, etc., are often reclassified experimental. Obviously I dunno the circumstances of the OP's Pipistrel, but I'm not surprised by it, either.
It's not real clear in the NOTAM but when you get assigned a "dot" as in "Yellow High wing Green Dot" you don't have to land exactly on the dot (and there's no expectation for you to do so). The idea is to set down near it, just don't land before the dot or float long (hense the advice to practice spot/short field ).
PP ASEL - IA
RV-10 N728TT - Flying
EAA Lifetime Member
WAR DAMN EAGLE!
In most cases, they want you at or beyond the dot. The whole point of the dot is they're putting someone down on the threshold behind you.
As for whether the XX can get into Custom, you'd have to ask them. I don't know their rules. We definitely won't take it in Vintage
I'd be prepared to go to the GAC.
Sometimes I detect a little nuance that there's something wrong with being in the North 40. I haven't camped in Home Built, but that's the only place I haven't camped with my airplane. I've been on both sides of 9-27 (sometimes referred to as the North 40 and the Far North 40), Vintage (the benefit of flying an airplane with a 1962 certificate date), the South 40, and so far south in the South 40 that we jokingly called it North Fond du Lac. I've had a great time, no matter where I camped. I've met some great people in each of the places I've camped (I've met a couple of jerks, too).
What do I prefer? Actually, I do like the North 40 relatively near the showers. The new shower house is a gem, very nice. The old one is adequate. The portable shower houses spotted here and there are adequate. The North 40 Cafe has pretty good food on its limited menu. The North 40 store is a good place to get ice.
I've heard people say that they like camping in this place or that because "it's close to the action". That also means it's close to hoards of people, not all of whom are aviation oriented. I feel comfortable that my belongings won't disappear when it's just a bunch of aviation folk; I'm not so sure when it's those who are only there to watch the air shows. And being far from "the action" isn't a handicap, as long as the trams and buses are running.
But the bottom line is that wherever you camp, you can be assured that you'll have an enjoyable time.
Cary
