Animal nest (most likely mice) found in wing, what to do?
I just purchased a partially completed Kitfox 7. The wings are covered thru the first coat of poly brush, the pink stuff LOL. When we were loading and unloading, I could hear something rattling inside. Sounded like small pieces of gravel. I suspected it might be mouse droppings. I've been looking inside the wings from the tip end and discovered there's some kind of nest back towards the tank in one wing. My problem is, I need to get it out of there, The second problem is, did they do any damage, such as chewing on a rib, or stitching. My big concern is, mouse/rat urine is very corrosive, These wings were covered about 5 years ago. Who knows how old the nest is. I feel I need to inspect for corrosion and if ok clean and treat to prevent any problems in the future, and this would include the full length of the spar. I'm thinking the best and most comprehensive plan would be to uncover the wings.
So what do you think I should do? Any suggestions?
Thanks
