Thread: Any Curtis experts here?
    Trying to find out what make this engine is. Someone suggested it might be a Curtis B8.
    Any ideas?
    Jan 2014
    Hilton, NY
    Try contacting the Glenn Curtiss Museum.
    https://www.glennhcurtissmuseum.org/contact.php
    Jul 2012
    Circle Pines MN
    If the B8 is the engine used on his record setting motorcycle then this engine in the photo appears to be very different from the B8.
    The engine shown appears to be water cooled, his bike engines were air cooled with deep fins on the heads. This also appears to possibly be two V-4 engines mated together by the increased spacing between the middle cylinders, Curtiss engines were consistent spacing between all the cylinders on the banks.
    I'm not sure what this engine is, but it may not be a Curtiss.
    crusty old aviator's Avatar
    Jun 2012
    You can't get here from there
    The case doesn't look like a Curtiss casting. This engine may be a homebuilt that used a lot of Curtiss components.
    Wow, cool find.
