Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 70
Thread: Web Cams
  1. #51
    biggles1998's Avatar
    Jun 2016
    U.K.
    Web cams all at once.
    Hi.. having three web cams available now is awesome the only problem is watching them all at the same time!! . I found this and made a live 3 way feed which might be useful..
    http://www.youtubemultiplier.com/597...b-cam-feed.php
    mike
    2016 1st time Oshkosh visitor, 2017 was hopeful but just not to be..but see my 2016 and upcoming 2018 adventure on mikelynnweb.wordpress.com Celebrating the RAF100
  2. #52
    Quote Originally Posted by spongebobiwan View Post
    Strange New Mysterious Aircraft appears at Oshkosh.Attachment 6510
    Well it looks like he was correctly directed to the right area on the airport down by ultralights.
  3. #53
    spongebobiwan's Avatar
    Janesville, WI
    LOL. Yes. Well, it does appear to be an ultralight. Perhaps even an ultra ultralight.
    Russ Zimmerman
    EAA Member #292524
    "Thanks Paul"
  4. #54
    Wrongway Feldman's Avatar
    Jul 2012
    Some where in the South Pacific,I also do Flyovers for the Green Bay Packers Home Games,GO PacK GO!!
    If you can find the Ferris wheell in the picture you get a cookie.
    If you can find the Ferris wheel in the picture you get a cookie
    Here is a hint: The Boeing Chinook is pointing towards it.
  5. #55
    Central WEBCAM
    is it just me or does the CENTRAL webcam not aimed right? seem to show Boeing Square but the nothing but tops of buildings and trees. Can they maybe point it to also scan the runways like it did last year?
  6. #56
    Sirota's Avatar
    Tucson, AZ
    Todd,
    Can the focus be improved on the South camera?
    Thank you,
    Dave
  7. #57
    Hartford, WI
    unfortunately, no. I think what we are seeing is the maximum output bitrate of the DSL and aging camera.
    however the Airshow will be streaming in the highest resolution ever..looking forward to it.
  8. #58
    I thought the cams would be showing the air show. It's going on, but the cams aren't following it.
  9. #59
    Hartford, WI
    Quote Originally Posted by admiralinwi View Post
    There is an entire stream dedicated to the airshow. check the EAA webcam page and its just under the 3 wayfinding tower cameras
  10. #60
    Down Webcam
    Now the only webcam that does show the runways and such is DOWN.... there goes my Tuesday morning...
