Thanks for the update Todd, I'm certain nobody wants that cam up and running more than you and your team does. Thanks for the effort.
Central cam is back online
It is on a different link.
Almost HD quality resolution, looks great, lots of pretty colors.
https://www.youtube.com/watch?v=MW0Y_e-Ee78
Just saw that! Can't wait to get there Monday!
It looks like at the moment they are programming the camera's movement tour.
Logic would assume when that programming is being uploaded to the camera those commands are using up bandwidth.
Disrupting the video stream.
That may be why the player/s is/are buffering once in awhile, they are tweaking the system.
Solution is to reload your browser.
The central camera at this moment is swinging north heading to Boeing plaza, Yippe!!
Someone give those guys some water especially Todd.
The old camera getting hit by lightning may have been a blessing in disguise.
This new camera is a vast improvement by leaps a bounds.
Looks like the original perch on the way tower was reached.
They should of pounded a flag in when the summit was reached.
A picture is worth a thousands Words.
Old Glory is really showing its true Colors.
You can now even see the Pink Shirts moving around up in the Air Traffic Control Tower
Yes, we did get all the way to the top, just barely. We had a 60 foot lift and all the way up it was still about 10 feet higher. But with a safety harness on, we were able to safely get the rest of the way.
More programming of both stops and trying to improve the quality more will continue as we try to fine tune the setting. Our biggest limiting factor of quality is still the DSL line and the limited bandwidth. The new camera has a new method of compressing the video that is allowing us to increase the quality a little.
Todd
Strange New Mysterious Aircraft appears at Oshkosh.
Russ Zimmerman
EAA Member #292524
"Thanks Paul"
I think that lift is in high gear or that video is in high speed mode.
Ether way its way up on the way tower.
https://twitter.com/EAA/status/888805046909063168
Nothing smells like a new camera in the morning.
https://pbs.twimg.com/media/DFWE8XWXoAA5Riq.jpg
