Thread: Looking for a kit plane
    My chapter is looking for a kit plane to build and then use for flight instruction...we would prefer something fabric covered with a steel tube frame, tricycle gear, and side by side seating. any suggestions would be wonderful
    Eric Witherspoon's Avatar
    Tucson, AZ
    Kitfox is the first thing that comes to mind when you say steel tube, tri-gear, side-by-side. There's a lot of them out there, so you might be able to find something in the pre-owned market that didn't get very far along. Someone with more Kitfox experience could comment as to which model is preferred for which features / do they make reasonable trainers...
    http://www.spoonworld.com
    rush city mn
    The Just Aircraft Highlander or Escapade Would be, by far, my first choice. A Gentleman i know at my home airport has built at least 3 and they are an amazing flying aircraft. The Escapade is convertible from tail wheel or tricycle, has a folding wing and a great use full load (if i remember right 700#)! I flew one at Oshkosh and it has great balanced controls and plenty of power on 100 hp. I hope to build a Highlander with a 912s when i finish my Chief project. Talk to Gary tell him Pat from Minnesota said to call.
    http://www.justaircraft.com
