Increasing the amount of torque will be a challenge, lowering what torque it has to a lower RPM is not too difficult, however, "lower" is a relative term; it's still going to be turning faster than the Vanguard. I think you should be able to get performance close to the vanguard.
How would you go about moving the torque lower in the power band?
I can increase the torque out put to the prop by changing the ratio in the belt pulley's but as I stated above I can only change them so much do to limit on space in the drive system housing.
Thanks for all the replys gents good info from y'all so far.
