Results 1 to 8 of 8
Thread: Questions for the DAR
    N404CX's Avatar
    Los Angeles
    This pertains to E-AB aircraft.
    1. Under what circumstances does the Special Airworthiness Certificate cease to be valid?
    2. What is the impact of the original builder removing the data plate?
    3. Is there a way forward after the original builder removes the engine, de-registers the N-number, removes the data plate and donates the project to an EAA Chapter?
    Thanks in advance for your wise counsel. -glen
    Quote Originally Posted by N404CX View Post
    Suspended, surrendered or revoked
    depends. In what context? He removed it to make the plane not flyable?
    A way forward to make the plane flyable again?
    N404CX's Avatar
    Los Angeles
    I presume he removed the data plate to disassociate himself from the project.
    Yes, to make the plane flyable again.
    If there's no data plate and paperwork, you have a collection of airplane parts, not an airplane that can be registered and flown.
    Dana
    N404CX's Avatar
    Los Angeles
    So assuming someone wanted to take this collection of airplane parts and create a flyable airplane, what would be the steps?
    Sam Buchanan's Avatar
    KDCU
    Biggest hurdle will be compliance with the 51% amateur-built rule. You need the build log for the plane to prove it amateur-built but if the builder was trying to distance himself from the project you may have a deal-breaker. If the log can be obtained and the plane is amateur-built then you can begin the registration process the same as a new build.
    Sam Buchanan
    The RV Journal RV-6 build log
    I know people have done it in the past. Have to research - will report back.
    do you have a bill of sale to prove ownership?
    Yes, you need a bill of sale.
