RG 400 antenna coax now available.
Experimenting with a new flat braid swager and ferrules. I doubled the 1.125” braid for this ferrule which is excessive capacity for 4 place electrical system grounds. Definitely work well for 6 place electrical requirements.
Note the seam on the Cessna 150 terminal. It’s a copper strap folded over the 7/8” braid. I’ll order .9” solid copper ferrules to try with this 1.125” braid. That should handle all 4 place electrical loads.
5/16” hole on the new ferrule for common aircraft battery bolts, 3/8” hole on the old Cessna braid.
Also I recessed the braid in the ferrule to allow a good seal with Dow Corning 732 RTV.
1.125” flat braid, 12” center to center, 1/4” hole and 5/16” hole with larger I.D. MS35489-16 grommet for the Cessna battery box. Sleeve is a flame retardant polyolefin heat shrink. $50
Pictured is a Cessna 150 7/8” wide battery ground strap that originally used grommet MS35489-12.
First set of Bendix P leads for a 182.
Printer is getting closer to replicating a Cessna 150 customer's wire stamping.
I now have 2 AWG red and black for battery wires.
Custom patch cables.
