Thread: GPS receivers
    Dec 2016
    Southern BC, Canada
    GPS receivers
    I've had two GPS receivers over the years, most recently one called Ultimate from Emprum. I use Air Nav Pro on my iPad II. When I first got these devices - they worked perfectly. Then they suddenly became erratic. The creator of the navigation software claims that Apple is constantly changing the IOS to make it stop working with external receivers. He claims that he is having to constantly update the program to "work around" Apple-caused problems. He says these problems are the same no matter which receiver you are using - he claims he fields lots and lots of complaints across the industry.
    Anyone have good luck with external receivers ? If so, what iPad version, what IOS version, what software, and what receiver combo is working for you ? Also, how long has this combo been trouble-free for you ?
    gbrasch's Avatar
    Arizona
    I cannot answer your questions but I will comment that I believe what he says about App le.
    Glenn Brasch
    Tucson, Arizona
    2013 RV-9A / 1952 Piper Tri-Pacer
    EAA member since 1980
    www.airportcourtesycars.com
    www.facebook.com/airportcourtesycars
    Northern IL
    Use an Android tablet and an EFB such as AVARE. Probably won't need an external GPS receiver and won't have the compatibility problems. Can add Stratux ADSB in for far less than the Foreflight options.
