built up wood spars for aircraft larger than Ultralights,
All, I am looking for aircraft by name for any that have or use the built up wood spars in them.
Example, Minimax uses a 1/16 plywood face web on the 3/4 x 1 upper and lower caps.
I am looking for aircraft that gross at 1320 or better, and use the I Beam and Plywood with upper and lower caps, or the box play and upper and lower caps.
i have the dimensions for the LMA 5, aircraft spar dimensions, that wing uses 8 and 5 inch tall spars.
i am looking for 6 inch and 5 inch spars. and suggestions
Thank you Robert
