Results 1 to 7 of 7
Thread: built up wood spars for aircraft larger than Ultralights,
    Nov 2013
    Mount Perry, Ohio
    All, I am looking for aircraft by name for any that have or use the built up wood spars in them.
    Example, Minimax uses a 1/16 plywood face web on the 3/4 x 1 upper and lower caps.
    I am looking for aircraft that gross at 1320 or better, and use the I Beam and Plywood with upper and lower caps, or the box play and upper and lower caps.
    i have the dimensions for the LMA 5, aircraft spar dimensions, that wing uses 8 and 5 inch tall spars.
    i am looking for 6 inch and 5 inch spars. and suggestions
    Thank you Robert
    Wachapreague Va.
    Kr2s. , gross is much lower though
    Justin, Texas
    Stinson L-5 has a box spar. Going even bigger would be the Fairchild PT series.
    Nov 2013
    Mount Perry, Ohio
    Ok, that is 2 to look up, thank you vaflier, and Craig. its an experiment. have a great week.
    Robert
    Broughshane, Northern Ireland
    Pietenpol Air Camper as modified for use in the UK, uses built up spars using 7/8" & 3/4" square spruce capstrips and 1/8" ply web on mostly one side. Various blocks between capstrips and ply on second side for portions of the spar.
    The aircraft is limited to a MTOW of 1200 lb.
    Nov 2013
    Mount Perry, Ohio
    i found those as well, I just got home with my new frame, so I can start building up the wing profile, and moment of inertia, that the tail has to produce in order to fly it cleanly.
    at this time the frame has a wing to tail coupling issue, I have to fix.
    thank you
    Foller D VII and D VII
