Results 1 to 10 of 15
Thread: Flanged lighting holes
    Mar 2013
    I am brand new to SW and I can barely get it around the patch. I have a friend that is halfway decent with it and he is giving me some dual but, I must admit it is a struggle. Any way, does anybody out there know a way to make flanged lighting holes for a spar shear web? I can make a hole alright but it sure would be nice to put a flange on it. Anyone???Buehler....Buehler....
    Try the "Bob Stick". Here's a video:
    http://www.eaavideo.org/video.aspx?v=820371239001
    Israel
    Do you mean making flanged holes in your SW digital model, or actually making flanges?
    Ha! I didn't even notice the sub-forum...
    cwilliamrose's Avatar
    Nov 2013
    SW Florida
    The easiest way, if you have a number of different parts that need this feature, would be to use a forming tool. The part would have to be a sheet metal part and you would have to create the forming tool (or tools if there is more than one size). Another way would be to use a Revolved Boss which would not require the part to be a sheet metal part but you will need to determine how big to make the hole because the flange will be inside the original hole when you're done.
    Below is a Swept Boss used to create a bead. The Revolved Boss works essentially the same way.
    Name:  SWx Bead Seq1.JPG
    I cut the hole first and this hole is the outline of the bead with the radii.
    Name:  SWx Bead Seq2.JPG
    This is the profile of the feature.
    Name:  SWx Bead Seq3.JPG
    The finished bead with the sketches shown.
    Mar 2013
    Whoa up here boys...I'm not much of a blogger or social media kind of guy so maybe I made a mistake. I posted this under SolidWorks forum I thought. SW short for SolidWorks. I am glad to see all of the quick responses though. As for making flanged holes in sheet metal, that's pretty easy. I think I made my first one about 35 years ago. Designing them in SW is another story. That requires a skill set I am struggling to master. Kinda like flying a taildragger for the first time, only much worse. So I have been able to draw my spar flange and I need to put a 1/4 inch flange on the 3 inch lightning holes I have in my SW sketch. How does one do this? A step by step procedure would be good for me. And by the way, on making holes with flanges on them in the real world, do yourself a favor. Buy a flanging hole punch. You will be glad you did.
    Mar 2013
    see my response below...
    Nov 2013
    SW Florida
    Here's the equivalent of a flanging hole punch in SWx;
    Name:  Flanged Hole in SM1.JPG
    This is the punch (forming tool). It makes the hole and flages it in one step.
    Name:  Flanged Hole in SM2.JPG
    Applying the tool to the metal.
    Name:  Flanged Hole in SM3.JPG
    The resulting feature.
    Mar 2013
    Mr. Pitts, excellent! So I take it I need to build virtual tool to perform this task? I will have my friend take a look at this...thanks.
    Nov 2013
    SW Florida
    Yes, there are some rules and methods to making the tools but once you do it a couple of times it will become easy. It's all in the help documents. Good luck.........
