Results 1 to 4 of 4
Thread: Magneto starting
    Magneto starting
    Some aircraft with two magnetos only start on one magneto.
    How is the second magneto removed from the circuit? Is it
    done at the ignition switch?
    Thx
    Jan Zumwalt - EAA #66327
    (\___/)
    (")_(")
    It depends on the airplane. Often, the ignition switch grounds out the magneto that doesn't have the impulse coupling when you turn the switch to START. In others, like my plane used to have, the mag switch is distinct from the starter, so I put it on L before pushing the starter switch.
    Auburntsts's Avatar
    Tampa, FL
    My ignition is setup like in Ron's plane--the mags are controlled separately from the starter but in my case the starting Mag (the left one) is a retard breaker with a starter vibrator (SlickStart) vs an impulse coupler.
    PP ASEL - IA
    RV-10 N728TT - Flying
    EAA Lifetime Member
    WAR DAMN EAGLE!
    Thanks for the help folks
    (\___/)
    (")_(")
