Page 20 of 21 FirstFirst ... 1018192021 LastLast
Results 191 to 200 of 209
  1. #191
    Frank,
    I just lost the two shortest riblets and had the material to make the two longer ones. Basically I just removed two and cut out the HAZ of the others and slip them down. One of the diagonals will get the HAZ cut out and re used. I carefully cleaned up the spar and am using that again. Everything is retacked after loading the sundry parts and may have it finished enough for a side by side progress pic Sunday.
    Jim
  2. #192
    Good to hear it wasn't major surgery.
    I'm impressed with your work - the best I ever did was throwing a bead line down a bit of stock back in High School.
  3. #193
    10/15/18 Yes I started over with a new fuselage Friday. The first one was rather dubious at best. So with much improved welding skills and sticking to gas (oxy/acet) welding Lets get to it.
    First pic is of the two new sides and this pic also displays the cleat system I used same as in the very first fuselage. The second side I did start using steel plate shields under the welds and failed to ignite the table top. Bomber idea.Name:  Fok fuse new.jpg
    Second pic shows a tubing cluster and the degree of notching involved. Those are all hand cut and requires lots of back and forth with test fitting. Oh my feet hurt that night.Name:  Fok fuse new 2.jpg
    Third pic shows some welding back where the top longeron does a step down and incidence change for the horizontal stabilizer. The tag end of the longeron there gets trimmed when the welding is all done.Name:  Fok fuse 3 welding.jpg
    Fourth pic is a shot from the front showing the fixture used to mock up both sides of the fuse so that the cross members can be fit and tack welded. And the fifth pic shows the fixture from the rear.Name:  Fok fuse 4.jpg
Size:  94.2 KBName:  Fok fuse 5.jpg
  4. #194
    Pics in a few days
  5. #195
    Great!
    It's a real statement to your diligence that you could look at your work with an honest eye and realize that there wasn't any fixes to be had, and it required a full do-over.
  6. #196
    This pic shows the end of the fuse after redoing the tail post. I had jammed that in one night and it was very strange the next morning it was crooked. Elves or gremlins me thinks
    Name:  Fok fuse 2 tail post is straight everything else is moving around with the welding.jpg
    Name:  Fok fuse new 7.jpg
    55 wire loops so far
    Name:  Fok wire loops 3.jpg
    Cowl hoops, combing, and gun mount stuff welding in this week. Plan to start painting this weekend
    Name:  Fok cowling and turttle deck hoops.jpg
  7. #197
    11/9/18, This weeks work after taking two tries at the curvy cowl tubing around the front machine gun mounts and still not happy. So I cut up some of my failed attempts and made the partial cowl supports that are near the adjustable rear gun mounts.
    Name:  Fok partial cowl at rear gun supports.jpg
    You guys also saw the start of the static front gun mounts that are now completed.
    Name:  Fok front gun mounts.jpg
    Yesterday I fabbed and welded in the cockpit combing tabs.
    Name:  Fok cockpit combing tabs.jpg
    And after messing with some other stuff I made the lower wing/fuselage cover. That is the rectangle laying on the work table. The fuselage tabs it bolts to have been drilled but have not been shaped yet. Tomorrow is going to be cold so I may get some time wire wheeling the fuselage in preparation for some epoxy primer if Sunday warms up enough.
    Name:  Fok lower wing cover.jpg
  8. #198
    11/25/18 Had some warm weather today so I finish welded the inside of the lower wing mount boxes and bolt carrier slugs and a couple reinforcing tubes where the engine bearer supports weld in and then started priming some 3 stations. I was having trouble with the epoxy going off too quick the last few times so I retarded the flash by decreasing the activator part B. At the end of the day I drilled the holes in the big clusters for these rear cabane cups. They should get welded in tomorrow and a second encapsulating coat of epoxy in this area. Manufacturers directions say if I re-coat within 24 hours I don't have to sand with 220. I likes not sanding.
    Name:  Fok primer 4.jpg
    Name:  MAM cabane rear socket Fokker C I.jpg
  9. #199
    A little progress today on the wing spar brackets. First pic is after the first bend on the practice 3 mm thick stock. Guess the form could have been deeper but I am working with 3" wide 3/4" mandrel stock. This pic shows the mandrel completely pressed. Third pic shows that I pulled the mandrel out of the form and placed it on its side in the press. Fourth pic shows I still have a bit of spring back, maybe 3 degrees. The die forms are changeable since the two front spar brackets have this angle and the rear spar brackets have more pronounced angle. Now I have to make the form so that I can bend the ears in the opposite direction so that the brackets can bolt to the fuselage. This material bent very easily in the fixture that was made.
    Name:  Fok lower wing spar bracket fixture 2.jpg
    Name:  Fok lower wing spar bracket fixture.jpg
    Name:  Fok lower wing spar bracket fixture 3.jpg
    Name:  Fok lower wing spar bracket fixture 4.jpg
  10. #200
    Progress 12/22/18, first pic shows that I started reassembling the fuselage. Seat, torque tube and control column, rudder bar, panel, cockpit floor, and the firewall mock up. Second pic shows the cockpit mock up poly panel. Some friends in Culpeper that are heavily tweaking an aluminum kit Newpie 28 told me about these poly panels for cowling and turtle deck mock up. I decided to use some of the material for firewall mock up too. Stainless can be tough to work with, better to fo the fidgeting in poly. Third pic shows the new throttle cross bar I made yesterday and I made some new panel brackets as well as you can see in pic 4.
    Name:  Fok progress pic.jpg
    Name:  Fok progress pic 2.jpg
    Name:  Fok progress pic 3.jpg
    Name:  Fok progress pic 4.jpg
