Page 1 of 21 12311 ... LastLast
Results 1 to 10 of 209
    Goggles Building a Fokker D VII
    Hi Guys and Gals,
    I realized that although I am keeping a build log on FaceBook and on The Aerodrome websites, I am a member of this association and should be keeping a build log here to share the journey with you all. With that I have some catching up to do. First off I had to build the Flugzeugwerke.
    Name:  Fok flugzeugwerke.jpg
    I started making tooling, build work tables, and buy an engine (yes that is an old Ford 300 inline straight 6) whih is the epitome of a bullet proof engine. The lathe is an 80 year old Clausing 100 series. I haven't used a lathe since I made dad a center punch in 8th grade shop. Purchased a welder, band saw, seconds in angle grinders and screw guns. Even bought a couple rivet guns since I was originally build all flight surfaces in in AL tubing. I built the tail surfaces in tube and rivet only to realize that I didn't trust a 2000lb plane with a 9 foot propeller giving 1000lbs of thrust to tubes and rivets. I am per Replicraft plans building this plane as a replica.
    Name:  Bracket and hinge making tools.jpg
    Name:  Fok beast.jpg
    Name:  Fok lathe.jpg
    Here are some of the parts I have built since September.
    Name:  Engine bearer brackets all of them.jpg
    Name:  Fok 90 degree bending fixture for the press.jpg
    Axle blocks
    Name:  Fok box O Fokker nuts.jpg
    Coweling nuts (Fokker Nuts)
    Name:  Fok brake.jpg
    Sheet Metal brake
    Name:  fok ball joints.jpg
    Ball Forks
    Name:  Fok pulleys horizontal stabilizer supports and undercarriage brackets.jpg
    Aileron Pulley Assemblies
    I have boxes with all my control surface hinges, wire tabs, aileron control cable pulleys and bracketry. Last week I received my order of streamline tubing from Aircraft Spruce and I have an order with Parker Steel in Ohio for most of the metric tubing for the fuselage, associated parts, and the 2 1/8" dia 3/16" wall tubing for my axle. I will post more to bring you guys up to date.
    Thanks for reading
    Jim
    1/27/17, Cool stuff going on. I can tell you to measure twice, then measure two more times. I made the plywood welding fixture yesterday. As you can tell I made the fixture to do both the right and left side undercarriage sections. Today i forged the tines of the ball forks, then fitted one of them to and welded it into one of the streamlined legs.
    Rather than move on to the next ball fork I couldn't help but start fitting the leg to the axle box. Take your time here guys and gals if you don't want to waste some expensive tubing. This is a complex cut on multiple planes and angles. I am proud not to have rushed as my fit was excellent hence I tacked it. I had to be careful as I have two sticks of this dimension tubing with only 10" extra per stick.
    Tomorrow I will weld a ball fork to the other leg and finish welding this being the left side assembly.
    Name:  Fok undercarriage fixture.jpg
    Name:  Fok undercarriage leg tacked.jpg
    Name:  Fok undercarriage complex fit.jpg
    Name:  Fok engine cart with Bertha.jpg
    Engine cart I made mocking up the forward Fokker fuselage in HD plumbing pipe. Very strong
    Name:  Fok cove cut spruce.jpg
    Spruce gap fillers
    Name:  Fok hinges and engine bearer brackets.jpg
    Hinges and engine bearer brackets
    Name:  Fok seat belt hardware.jpg
    Seat belt hardware
    So you saw current work from the last day or so and some more catching up of parts already made.
    Peace
    Jim
    Catching up some more
    Name:  Tabs and clips.jpg
    Tabs and clips
    Name:  Fok axle box bending fixture.jpg
    Axle box bending fixture
    Name:  Fok Jacobs hub.jpg
    My new still wrapped Jacobs hub
    Name:  Fok model so far.jpg
    Engineering model in CAD as I was going to do all AL originally
    Name:  Fok N struts aint they purdy.jpg
    I made some N strut cups on the lathe purdy huh
    Name:  Fok nuts and throttle.jpg
    Throttle with hand made vrass rivets
    Name:  Fok officer.jpg
    My task master
    Name:  Fokkefr DVII of Lt. Aloys Heldmann (Jasta 10) 15 kills later flown by Red Baron's brother.jpg
    This is the recreation I am going for of Aloys Heldmann
    Peace
    Jim
    Neat project. You mentioned Aerodrome at the beginning, but this is a scratch-build project, correct?
    Also, what engine is that?
    Quote Originally Posted by Fokker Builder View Post
    My task master
    Wrong war. :-)
    Ron,
    Here is a link to http://www.theaerodrome.com/forum/ it is not Robert Baslees company. There are many builders, enthusiasts, and modelers including resources, litterature, and research into the Great War, pilots, and aeroplanes.
    The engine I am using is a Ford 300 IL 6 from 1979. This engine is the epitome of bullet proof. It has been used in dump trucks, UPS trucks, ramp vehicles, automobiles and small trucks for over 30 years. It was designed to operate between 3000 and 4000 RPM all day and do it for decades. 165 to 185 hp yeild with 367 tq. I am putting a 1-1.97 PSRU as well as a 4 barrel intake with a Holley carburator. Should wind up with about 190 to 200 hp and 900 tq at the prop. Looking to run between 104 to 110" propeller with a 9" cord.
    Thanks
    Jim
    Hi guys and gals,
    2/5/17, Wow, this is cool. Big pieces of the plane. Both right and left side of the basic undercarriage legs. I do have to bend some 2 mm 4130 for the two U shaped clips that get welded in for the bracing wires and this week I will make templates and cut 1 mm 4130 for the bungee cord assemblies that weld on each side of the axle blocks. The actual bungee tubes should arrive in 3 weeks.
    The welding went flawlessly. There was hardly any movement in the position of the ball forks in the jig. They didn't even move the entire 3/16" I allowed for. Thanks Jeff, best to be safe and sage advice.
    D VII
    :work:
    Name:  Fok undercarriage legs.jpg
    You probably said (but I couldn't read it through the drool on the screen), but: What kind of welding are you doing? TIG? Looked at what might have been a TIG torch in one of the shots.
    When/how did you learn to weld? I'm retiring this month, and have been considering welding classes at the local community college.
    Ron,
    TIG is the bomb for beginner welders. MIG you have to work too fast with flux core, even with gas and wire I just feel rushed. Took a couple classes but really just started building custom motorcycles years ago. I have a $400 TIG machine with no foot peddle. Just have to play with amperage based on the metal you are welding. No AL with this machine though but hey, I am building a 100 year old plane. Here are some more pics.
    Name:  Fok engine and cart together.jpg
    Finished engine cart mocking up Fokker engine compartment. I will be making new engine mounts this week as have to drop the thrust line.
    Name:  Fok axle block success.jpg
    Axle block front and back covers plus the bending jig
    Name:  Fok hinge straps being drilled.jpg
    I hear that big guy making hinges has lost 20 lbs in the last month
    Name:  Fok flugzeugwerke lathe.jpg
    Better shot of the octogenarian in the shop
    Name:  Fok forming tool.jpg
    Make one of these, must have
    Name:  Fok new organization.jpg
    Had to create more accessible tool storage
    Name:  Fok round bending fixture.jpg
    Made a few bending tools for the Harbor Freight press. Change out the whimpy legs that are supplied and install 4 X 4 1/2" legs so you don't have to bolt it down
    Name:  Fok welder.jpg
    Tiggy set up, SB starting
    Enough for tonight
    Jim
    falcon21's Avatar
    Wisconsin
    Interesting, I find MIG relatively easy and TIG to be harder. In high school we only had two TIG welders though so it was hard to get some decent time on one to get good at it. We also did oxy-acetylene welding, that was fun.
    Dec 2016
    Zionsville, Indiana
    I am a self tough welder. I started with gas and practiced welding aluminum with oxy-acetylene. I did it just because it was hard but there were several guys in town that did it all the time to help me. When I started TIG welding, I found it easier and I attribute that to the similar visual clues between gas welding aluminum and TIG. For things like fuel tanks, I think it is the best welding method for the long sheet metal joints.
    In the first years I was doing race car work, we could built cars with aluminum fuel tanks. I gas welded all those tanks. I did use TIG when I installed bosses.
