Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Building a Fokker D VII
  1. #21
    Well I know I shouldn't but I feel like an ass-umer. I have had problems with my TIG welder and as such decided to switch to gas welding. I did all my trouble shooting of the TIG process except check the bottle of argon. Today was the final check by returning the gas and asking for an uncontaminated bottle. Turns out I had erroneously been given an an argon blend. Hooked it back up this afternoon and wouldn't you know I wasted 3 weeks with no TIG welder because of being given an argon blend instead of pure argon. At least i didn't ship the welder off to tech for service.
    I do believe if something is learned then failure is not a complete waste. Man with all the welding experience I have I shouldn't have trusted that guy or at least it should have been the first thing I checked.
    :blush:
    Jim
  2. #22
    3/24/17, I rocked this today. Got 7 cross tubes notched and tacked in today. Off to an EAA meeting tomorrow and then back to hard weld as much of the new tubes as I can reach. Get the rest when I flip it over end of the week. Sunday I will start jigging up so I can start pulling the longerons in as I head toward the tail. Pictures Sunday night.
    Jim
  3. #23
    3/26/17, Last few days work. I have the front 16 cross tubes tacked and welded in on what will be the underside of the fuselage. These will get welded on the upper side when the fuselage gets turned over.
    You can see some of the jigging of the fixture in these two pictures. That was actually a process that started with a few 8' 2 X 4 uprights and then transitioned into just tabletop lock-downs. As a bay would get tacked, a square was screwed in locking in the upper and lower longerons. Then the lower lock-down was moved after and raised and narrowed as the longerons past the the cockpit. If you look closely in the first pic you can see how the longerons are coming closer toward the tail-post.
    Name:  Fok fuselage front 2 thirds jigged and under side welded top and bottom cross tubes.jpg
    The second picture shows a failed tack weld where the top longeron steps down for the horizontal stabilizer and elevator assemblies. Boy I hate in when I start bending some tubing and my tack weld breaks. Guess I should have welded that completely first. I do have a weldment I am going to make on the lathe before I weld in the stern-post and tomorrow I am taking mom to the doctor. Guess I will weld up what I have on Tuesday and make the turning Wednesday. Should be ready to flip the fuselage over by end of the week.
    Name:  Fok fuselage failed tack.jpg
    Jim
