Results 11 to 12 of 12
Thread: SOLIDWORKS is horrible
    I'm going to copy this to a new posting about what I wish SW could do. I don't like getting messages about SW is Horrible. It Isn't!
    I'll work on a list and keep posting things as I encounter and/or remember them. Here are some things I like about TurboCAD I wish were as easy or possible in SW.
    Layers - I use layers to deal with clutter so you can easily turn things off. I can create layers in a poor way by creating multiple sketches on the same plane and then turn them on or off but all the inactive layers will be grey and hard to sort out what you are looking at.
    When you are drawing a line there is this annoying thing of wanting to keep drawing lines chained together like a poly-line. If I just want a line I just want a line. I like the arc at the end of the line but at times would like to control the center point of the arc while drawing not just the current 2 choices. To do it you need to stop and select arc and draw an arc then go back to drawing a line.
    I'm used to having all my drawing and snap icons available to turn on or off what I need on the fly. I may not want to snap to the center of a segment or I may want to snap to the center point of an arc.
    The same thing with creating construction geometry. Once you start drawing a line you can't just click construction and switch to construction. You need to select it first or after you are done.
    All these things mean extra clicks and time spent finding an icon. The trim icons are buried so it always takes at least 2 clicks. If you want to extend a line it's a pain to get to the icon and then it seems you have to get it all over again to extend another line plus you can't type in a value to extend it, you have to select the line and give it a dimension or edit it's value, but if it was created as a midpoint line you can't extend one end by entering a value.
    At times it would be nice to turn off relationship creation while allowing snaps so you can create geometry which uses something as the reference for easy creation but isn't tied to it. Not every relationship should be permanent.
    When creating parallel lines like for laying out an airfoil in TC I select parallel line, pick an existing line and move the cursor or type in an offset value (+ or -) and it's done. I keep on creating parallel lines until I select a different function.
    In TC I can set a reference on an object (temporary or permanent), like a corner or center, grab that point and snap it to another object.
    The difference is speed and ease of use. I still like the 3D capabilities of SW but it's taken me longer to model a wound wire ferrule than it did to build the tooling and make over 100 parts.
    http://nc3397.blogspot.com/search/label/Wire%20Ferrules
    This morning I finally got it to work and I'm delighted, no on to the wing rib.
    cwilliamrose's Avatar
    Nov 2013
    SW Florida
    I replied in the new thread.
