Results 1 to 10 of 11
Thread: Homebuilt Fleet Sizes
    This table shows the number of particular homebuilt types that were registered as of 3 January 2017. The value is the fleet size at the end of the labeled year.
    Type
    Count
    Air Command
    58
    Aventura
    90
    Avid
    430
    Baby/Junior Ace
    284
    Bede BD-4
    102
    Bede BD-5
    68
    Benson Gyro
    323
    Bowers Fly Baby
    185
    Challenger
    1205
    Christen Eagle
    232
    Glasair
    709
    GlaStar/Sportsman
    480
    Harmon Rocket
    94
    Hatz
    128
    Kitfox
    1167
    Kolb (Ex-AB)
    235
    Lancair (All Models)
    1030
    Lancair IV
    317
    Midget Mustang
    279
    Murphy
    218
    Pietenpol
    391
    Pitts (EX-AB)
    638
    Pulsar/KIS
    154
    Quickie/Q2/Q200
    178
    Quicksilver EX-AB
    169
    RAF-2000 Gyro
    145
    Rand KR-2
    230
    RANS
    901
    Rotorway
    517
    Rutan Long-EZ
    487
    Rutan Varieze
    319
    SeaRey
    343
    Sonerai
    234
    Sonex
    596
    Steen Skybolt
    288
    Stolp
    459
    Stolp Starduster
    392
    Thorp T-18
    304
    Vans RV-3
    176
    Vans RV-4
    1072
    Vans RV-6
    1985
    Vans RV-7
    1325
    Vans RV-8
    1319
    Vans RV-9
    687
    Vans RV-10
    453
    Vans RV-12 (EX-AB)
    63
    Velocity
    291
    Volksplane
    130
    Zenair EX-AB
    1015
    Auburntsts's Avatar
    Tampa, FL
    I'm guessing you pulled this data from the FAA registry by make which will exclude non-standard registrations (e.g. Van's RV-7 vs. Bob Smith Special 7)? I ask because the Van's numbers, and most likely other makes are low-- I estimate by possibly as much as 20%. For example, your data shows only 453 RV-10s while Vans site shows 819 self reported first flights--that's a pretty big discrepancy.
    PP ASEL - IA
    RV-10 N728TT - Flying
    EAA Lifetime Member
    WAR DAMN EAGLE!
    gbrasch's Avatar
    Arizona
    Interesting, to add to Todd's comment, here are the numbers from Van's site:
    As of January 6, 2017 9,582 RV aircraft have been completed and flown!
    Listed by Model
    RV-3 295
    RV-4 1,401
    RV-6/6A 2,597
    RV-7/7A 1,553
    RV-8/8A 1,373
    RV-9/9A 1,035
    RV-10 819
    RV-12 490
    RV-14/14A 19
    Glenn Brasch
    KRYN Tucson, Arizona
    2013 RV-9A
    EAA member since 1980
    www.airportcourtesycars.com
    I try to find non-standard registrations as much as I can... for the RV-10, for instance, I use:
    Like "*RV-10*" Or Like "*RV 10*" Or Like "*RV10*" Or Like "*VANS 10*" It certainly doesn't catch the "Joes Ten" registrations, but its unknown how often those sorts of variations are made.
    If anyone has an N-Number list, I'd be happy to run them against the master list to hopefully improve my type filters.
    Also, I suspect Vans' list includes:
    - Foreign-registered RVs, and
    - US RVs that have been deregistered
    ...which mine doesn't. There are, for instance, about 350 RV-6s that have been removed from the registry. These will include both destroyed/abandoned aircraft as well as those exported to other countries. 22 RV-10s are listed on the deregistered list, of which 15 have been exported.
    Also, for the RV-12, I list ONLY those registered as Experimental Amateur-Built. My database shows 523 RV-12s of all certifications.
    Auburntsts's Avatar
    Tampa, FL
    Dang, how could I miss the obvious about the foreign builds? Of course you are correct and that explains the discrepancy.
    PP ASEL - IA
    EAA Lifetime Member
    WAR DAMN EAGLE!
    I don't see one Fisher Airplane. I know of three that are registered and flying today. I own one. I am sure there are a lot more then the three I know about. Maybe Fisher was left out for a reason that I do not know about.
    All aircraft types are extracted using a filter process that has to be set up manually. They do not automatically "pop out." If an aircraft type is not shown, it's because I haven't set up the appropriate filters for it.
    Best I can do with my Fisher filters is 149 total aircraft. Of those, 96 are definitely Experimental Amateur-Built, 34 have ambiguous certification (none listed in the FAA registration entry), and 17 are Experimental Light Sport (which wouldn't be included in my EAB list).
    That's interesting. I was under the impression that a Light Sport certificate was for E-LSA airplanes, for which none of the Fishers would qualify. They can be Experimental, and they can meet Light Sport Aircraft limits, but they can't be registered as E-LSA. Unless you get a DAR who makes a mistake, and apparently those just never get corrected. I think there has been a fair amount of confusion and inconsistency around the Light Sport rules. For example, I own an RV-12 that was built and is registered as E-LSA... but the manufacturer is listed as the builder, not Van's as should be listed.
    I can see why it's such a challenge to produce anything more than general results, or comarative year by year results from that database. There is very little consistency and almost no absolutes thay apply across the board.
    You're absolutely correct...the way the rules are now. An airplane can be registered as Experimental Light Sport only if the kit maker goes through the process to get approval of an example of the aircraft under the Consensus standards
    However, when the Light Sport process was implemented, there was a transition process. For instance, they allowed non-Part 103 compliant aircraft register as Experimental Light Sport without requiring showing compliance with ASTM standards.
    At the same time, they allowed ANY homebuilt aircraft, not yet certified, to be licensed as Experimental Light Sport aircraft if it met the Part 1 definition. A number of homebuilders took advantage of the window (IIRC, it was about 18 months long) and licensed traditional homebuilts as ELSA. I was actually contemplating buying a Fly Baby project at the time, to license it as ELSA.
    I strongly suspect that most, if not all, of those Fishers fell under that category. I don't have access to my database at the moment, but I believe all the Fisher LSAs I saw were the transition certification category. It's either 48A or 48B (48C is for aircraft transitioned from SLSA to ELSA).
